thealexdexter's avatar
Jun 01, 2016
Sag with stable loads.
If I'm sagging 6" loaded up on stock suspension, how much can I expect to sag with upper stable loads ? I'm thinking the load is the same so at most I would reduce sag by the thickness of the rubber block. It's about 3" tall. Am I going to sag 3"?
  • Buzzcut1 wrote:
    From my experience the lower stable loads reduce the sag much more than the uppers do
    Would have preferred that but not available on my truck.
  • Our AF dropped the rear end about the same. We only have lower overloads. Our RAW is about 6600 unloaded.
    The right side was about 6 inches and the left about 5. I added Air rides, which, with about 50 lbs right and 40 lbs left, levels it side to side and puts the loaded height about 2 inches below unloaded with the overloads just touching.
    If we put too much air, it starts to feel very top heavy. So I only put what it takes to push the headlights back down.
    I then added a rear sway bar which gave it a steady feel on the curves.
    I considered stable loads, but took advise from several of the guys on RV.net and it's really working well for our rig.
    You can always add them later if the air bags don't do what you want them to.
  • It looks like you might have 2015 Denali HD from your profile picture. Is it a 2500 or 3500? I have a 2015 Silverado 3500HD SRW with an Arctic Fox 811 and the truck sits level, fully loaded, with nothing but upper Stableloads.
  • Airlift ultimate is on. Installation was simple. Some complained of plastic fittings and such. Mine were all metal. All parts were high quality. Unloaded ride with less than 3 psi seems like stock. Haven't tried loaded yet... Soon.
    Only issue was e brake clamp replacement. No way that's going back on. Cable is too short to fit around air bag and into clamp.
