thealexdexter's avatar
Jun 01, 2016
Sag with stable loads.
If I'm sagging 6" loaded up on stock suspension, how much can I expect to sag with upper stable loads ? I'm thinking the load is the same so at most I would reduce sag by the thickness of the rubber block. It's about 3" tall. Am I going to sag 3"?
  • Was hoping to avoid airbags but sounds like the only way to get height back. 1-2" isn't worth the effort. I'd like 3+ to get the stinger hitch higher off the ground . Ya I'm probably 5200 fully loaded with trailer weight. Lower stable loads not available for my truck. Torklift said there isn't enough room.
    I kind of like the air ride ultimate because they can run zero pressure. Guess I may need to shift research direction.
  • You have a 3500 then with an upper overload spring correct?
    The upper stable load will engage the overload sooner but I don't think you'd cut the sag in half. Maybe reduce it by an inch or 2 only? I think the overload will pick up just as much weight and not a bunch more only being a single shorter leaf.
    Quick way to test it. Cut 8 little blocks out of 2x4s and stick them in there and see what it does. Or whatever thickness the stable loads are.
    Betting upper and lower stable loads or some Timbrens or airbags with low pressure will be needed to get it where you want it though.
    Those campers are as heavy as they get fr the size of them. Same as the old 860 models I have/had and although I've never weighed the camper, based on air pressure in my bags if I air up to empty ride ht, I'm between 4-4500lbs ready to camp.
  • Try Firestone air bags
    Wonderful
    Gets the springs working again and allows leveling
