Ray___June
May 09, 2014Explorer
Check the size of the wiring to the furnace. Most manufacturers back then they used smaller wiring than they should have. Many times you can't get the amperage from the batteries to make the fan blow hard enough to activate the sail switch. Often it will work when plugged in, or when the engine is running, but not on battery.
44,056 PostsLatest Activity: Jan 12, 2020
