Old-Biscuit
May 09, 2014Explorer III
If you really want to tear into the furnace.......
Here is a service manual for older Duo-Therm Furnaces......LINK
BUT
If it works on shore power......then it will work on battery IF your battery is any good.
Same wiring goes to furnace......either converter supplies the necessary 12V DC power or the battery does.
Get your battery system fixed.
Either your converter (charger section) is not fully charging battery
AND/OR
your battery is not able to hold a good charge and voltage drops off quickly.
You should be able to run furnace all night on just battery power.
BUT
AND/OR
44,056 PostsLatest Activity: Jan 12, 2020
