bobndot wrote:
jackquontee wrote:
You can use the same connectors for cable and satellite.
Bruce
Thank you much!
Hi Bruce . I think when the tech suggested the f81's , he was ref. to the automatic sat finding Tailgater system, where the sat signal as well as the 12v power to operate the auto-find motor comes thru the same single line.
The tech swapped them at n/c so I just let him do it.
When I had a non powered dish, I always used the standard connector as you stated without any problems.
I just posted this info in case someone has a problem with quality, it may or may not help.
Bob
At the connector you should have no problems with the standard connector. Of course, you can always swap out the connector/coupling with a 3 gig one. Where you run into problems is with splitters. You must have a splitter capable of transferring power for a powered dish or LNB.
Bruce
