sbryan
Mar 31, 2021Explorer II
I bought a second antenna and mounted it on the plastic cowl in front of the windshield. It is still occasionally blocked by the camper but far less frequently. It's an easy fix and the plug under the dash by the driver's left foot is easy to swap back and forth when the camper is on or off the truck. The antenna on the roof is in the best location but the alternate location has worked well for me.
- raybucknerFeb 09, 2024Explorer
Do you know if there is a way to split at the plug under the dash to hook up both antennas so I don't have to switch it back and forth?
- Tango424Feb 20, 2024Explorer III
What plug are you talking aboit? The antenna connections? raybuckner Depends on the connectors on the cables if it is a stick in type like a car radio you could do a y cable but may cause issues you could get or make a antenna switch which would work better theyre easy to make if you understand basic electronics and can solde
44,071 PostsLatest Activity: Aug 30, 2026
