Bert_the_Welder
Apr 03, 2021Explorer II
deserteagle56 wrote:Fishbreath wrote:
Here is a post I did adding an XM/Sirius antenna to the hood. It is magnetic and I can move it from the windshield area to the front of the hood if I need to. (It is on a 2019 GMC, but the idea should work for any truck)
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30134476.cfm
This is what I did also. Magnet mount antenna sitting at the front of the hood. Never loses signal.
But since your hood is probably aluminum the magnet mount won't work. A lip antenna mount of some sort would have to be used.
For alum panels you might try, if accessible, gluing a steel plate or another magnet to the back side of where you want the new antenna mounted.
44,071 PostsLatest Activity: Aug 30, 2026
