AF 811-Eagle Cap 850-Lance 855S. Lets hear it; which one would (did) you purchase and why? Which one did you look at/not purchase and why? Good/bad/ugly...lets go! Tx, Bill
In reference to the flex propane line supporting the slide .... We had a propane leak , or at least the dectector would go off when we had a breeze from the passenger side . We were told that the hose was crimped and causing a leak . After replacement of said line at $$$ we still had a problem , replacement of the regulator more $$$$ , after all that $$$ spent the problem was the hole were the tube fed the hot water heater . We caulked it an no more problem !
