I have a 2003 Ford F450 with a 6.0 diesel. Does anyone here use a scan gauge 11 for monitoring their engine. I would like to monitor motor functions as we travel. Voltages, EGT, oil pressure, and so f...
I have an edge insight CTS. You can monitor up to 10 points at the same time and set it up to alarm at specific points. For the EGT you will have to drill and tap the exhaust manifold. Other than that it just plugs into the OBD port under the dash.
