I have a 2003 Ford F450 with a 6.0 diesel. Does anyone here use a scan gauge 11 for monitoring their engine. I would like to monitor motor functions as we travel. Voltages, EGT, oil pressure, and so f...
The SG2 uses the OBDII port for all its queries. If the coolant temperature is not digitized and uses an analog sensor, FWT will not give you a reading. The same is true with EGT since this is not a stock parameter that is fed to the ECU.
