Kayteg1 wrote:
jimh425 wrote:
Everyone has always told me that the batteries should be the same age. .
They also tell you to not put 2 different oils into your engine and not to mix vodka with beer.
Now that we've established you mix vodka with beer and mix two oils for your engines, the full quote is below.
"Everyone has always told me that the batteries should be the same age. However, I think you have another issue because they are some distance apart. I think I would consider another switch and charge them separately and run them separately as well."
By now, you should know better about taking quotes out of context. I suggest you should allow other people's comments to stand on their own. If you want to revise your comments, go for it.
