Mickeyfan0805
Jul 16, 2013Explorer
path1 wrote:
Last year I also had "misfire" codes. What I found to be helpful was a search on google and found several articles that got me going in right direction. Took a lot of messing around but finally found problem (fuel injector elec connection) If my RV would of been my daily driver I would of been in trouble, took a long time to find problem. http://www.google.com/#output=search&sclient=psy-ab&q=working+%26+misfire+code&oq=working+%26+misfire+code&gs_l=hp.12...2494.12807.0.15297.24.20.1.3.3.0.154.1619.18j2.20.0....0...1c.1.19.psy-ab.8uB-vEeZ6xw&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48705608,d.cGE&fp=41c472d8ef9be405&biw=1366&bih=599
That was interesting - thanks. One of the suggested issues is a bad battery. Since it is only happening when I tow, it makes me wonder if the extra load of being connected to the trailer is causing too much draw on a weak battery and creating the problem. May or may not be it - but it's a cheap check!
