cwmoser's avatar
cwmoser
Explorer II
Oct 28, 2016
Seeking th perfect Couples Trailer - just me and my wife ...
I'm trying to find the perfect "Couples Trailer" for just me and
my wife. I'm 6'2" but can deal with a short mattress if necessary. We are first timers but have been looking and asking lots of questions. Just haven't found anything that jumps up and tells me to pull the trigger.
These are some things I think I want:
- Queen-size bed - Murphy be nice, prefer North/South bed
- Full bathroom - not a wet bath - separate toilet and shower (wife demands this)
- Under 4,000 lbs - towing with my 2002 Lexus LX470 SUV, 6,000lb tow capacity
- Prefer 7' to 7.5' wide so I can see the rear more easily.
- When not in use, it will be parked outside in driveway - no shelter - water, sun deterioration?
Some Travel Trailers on my short list so far:
- R-Pod 180 - 2800lbs 19’ Slide, dry bath
- Lance 1685 – 4032lbs, 21’ x8’ Slide dual-axle
- Lance 1575 – 2915lbs 20’ single axlefold out arm shower Front window, power jack. Slide
- Apex Nano 191RBS – 3315 lbs, N/S bed, 7.5’ wide, 22’ long, Slide
- Starcraft Launch Mini 17QB – Queen Bed, 3,000lbs, 21.5’L, 7’W
- Rockwood Mini Lite 1905 – 3127lbs, 20’ long, 8’wide single axle
Love to dump the dineete table and replace with a Sofa.
Don't want to overtax my SUV.
My questions are:
- Of these Travel trailers, what is your opinion as to function and quality?
- Got any better suggestions?
Thanks -- Carl
  • RoyB's avatar
    RoyB
    Explorer III
    Wife and I looked at the JAYCO 213X a few years back (2010) and it would fit our liking just fine. I would be using a 1/2T Ford F150 however... This might not work well with the smaller SUVs..
    The rear slide out bed setup would be great for us and not take up any inside room. We also liked the idea of converting the bicycle storage area in a small storgae area just inside the the outside door and use the the rest of the middle area for an office/computer/Radio setup room.. The bunk beds remove very easy... Even did a drawin of what it might look like haha...
    Thought about it for a few months and we still are running the off trail areas with our OFF-ROAD POPUP trailer setup.. hehe
    If you are not into the RV TRAVELER mode the smaller trailers are most definitely the way to go...
    Roy Ken
  • bgum wrote:
    Airstream Bambi 16 or 19 ft.
    I agree, the smaller Airstreams may be just right for you, Colonial Airstreams on line a great place to see all of the models with lots of photos,
  • Looks like you are settled into the right class of trailer but you also need to pay attention to the hitch weight. The trailers floor plan can put more or less weight on the tongue depending on for instance where the kitchen is located (at rear or at side). A few years ago I towed with a Mercedes GL450 that had 7500# tow capacity but only 600# hitch weight capacity. Even with an ultra-light trailer that had a 480# advertised hitch weight it was difficult to stay under (advertised weights typically don't account for the weight of the battery and propane, 2 items that usually are installed at the front).
    With the LX470 you may won't to confirm if it has auto-leveling and if so, can it be turned off. A smoother pull is achieved with a nice weight distribution, anti-sway hitch (like the Andersen WDH) but WDH's actually work against the auto-level function and need to be turned off. If yours is auto-level and can't be turned off, then stick with a hitch that does anti-sway only and let the autolevel take care of weight distro. Lastly, shop for a hitch that not too heavy (Hensley's and Proprides are heavy) since you don't want to use up hitch weight capacity too much on the hitch itself.
    Our TT was just the 2 of us and we chose one that had a Rear Living style. It put the kitchen on one side and theatre chairs on the other.
    Good luck with your travels.
    Yeah, forget the Murphy bed as you'll lose a HUGE amount of front pass through storage compartment space. Some of those you've listed have a smaller than 6 cu ft fridge, some are single axle ... forget those also. Also forget any that are less than 8' wide, especially ones without a slide ... buy towing mirrors instead. ;)
    We downsized 3 yrs ago once our boys no longer camped with us to a 19' couple's trailer I can put on pretty well any campsite except those terraced and intended for tents only. Pics are at the link below.
