rhagfo
Oct 18, 2014Explorer III
I don't believe any current 150/1500 has a full floater either. Full floaters have several advantages.
Bearings are oil luberaced
You have four bearings not just two!
Wheel doesn't fall off with broken axle
Much higher weight ratings
Ford made a LD F250 with a semi floater I think in the early 90's and RAM made the Mega Cab 1500 on a 2500 frame, with full floating axle
In about 2006 to 2008 I think (years might be off).
Most semi floaters seem to break outside the bearing, causing loss of the wheel and tire.
