buddyIam
Oct 18, 2014Explorer
SMKenttner
I believe the 9.75 is a C-clip design see below:
Ford 9.75" Axle Parts, Gears, and Upgrades
Axle Specifications:
Ring Gear Diameter: 9.750
Diff Cover Bolts: 12
Ring Gear Bolts: 12
Axle Spline Count: 34
Axle Shaft Style: Semi-Float
C-Clips: Yes
Pinion Support: No
Pinion Nut: 1-1/8"
Pinion Crush Sleeve: Yes
Carrier Breaks: No
Dropout Carrier: No
Max Output Torque: 1,360 / 1,250 ft-lbs
Max Cont. Torque: 5,100 / 4,600 ft-lbs
Torque Specifications:
Pinion Preload New: 15 to 19 in-lbs
Pinion Preload Reused: 6 to 8 in-lbs
Ring Gear Backlash: .006" to .010"
Ring Gear Bolt Torque: 75 ft-lbs
Carrier Bearing Caps: 70 ft-lbs
Popular Applications:
Ford E-150 / E-450 Van 1999 - 2010 Rear
Ford F-150 / F-250 1997 - 2010 Rear
Ford Expedition 1997 - 2006 Rear
Lincoln Navigator 1997 - 2005 Rear
Axle Images:
Axle Details
The Ford 9.75" axle is a slightly smaller version of the Ford 10.25" / 10.5" Sterling axle and features a 9.75" diameter ring gear with 34 spline semi-floating axle shafts. While its bigger brother is found under full-size Ford trucks, the 9.75" model came as standard equipment under almost every modern Ford F-150 and '97 to '06 Expeditions.
Ring Gear Bolts: 12
C-Clips: Yes
Pinion Support: No
Pinion Nut: 1-1/8"
Carrier Breaks: No
Dropout Carrier: No
Axle Images:
Axle Details
