Heiny57
Jun 14, 2016Explorer
cbshoestring wrote:
How can you get a CDL without knowing how to back a rig???
How can you get a class A without knowing how a 5th wheel works, or how to drive a manual transmission??? Truck driving schools taking advantage of high unemployment and the high demand for semi-drivers, that is how!!! By the way, FMCSA (the FED in charge of truckers), has recently caught on, so now those CDL's come with a restriction from driving manual/5th wheel without testing on equipment that has it.
Still wonderig if the OP cares to comment on the posted speed limit???
Just because the OP got nervous, does NOT mean the trucker did anything wrong. Was the truck driving near speed limit? Did the truck stay in THEIR lane. Just because it made you uncomfortable, doesn't mean that driver was doing something unsafe, or something that they were not totally comfortable doing.
You may think it is scary going 3 wide up the curvy hills on the PA turnpike into the Allegheny Mountains....I've done it so many times with a tractor-trailer on either side of me that I barely raise an eyebrow unless there is lane encroachment. I'll share the highway with anyone...I refuse to share MY lane.
You state the side railing was "only a foot or two away". Assuming you where in the center of the lane--you where also a foot or two from the white line that seperates the two lanes. Even if that truck came onto the white line, it was still a foot or two away. Sorry, sounds as if that railing scared you, you were "hugging the zipper"...which put YOU closer to him.
X2
