lbrjet wrote:
Kabo, if you start a new thread in the tow vehicles section you should get some responses. Post your stickers as well.
Good point....... hijacking the OP thread doesn't help the OP with her questions.
OP
Like Ibrjet mentioned in his reply about your vehicles axles being larger than his F150...... your tow vehicle has a 4000 FAWR and a 4280 RAWR.
All of the hitch weight from a TT goes on the tow vehicles rear axle. I didn't see your vehicles rear axle scaled weight weight but many 1/2 ton size vehicles weigh in the 2500 lb range. This leaves 1780 lbs before exceeding rear axle/tire load ratings. This is a estimate but shows you how to do the math. Actual scaled front and rear axle weights are needed with any vehicle that will be carrying a load.
