I have a 23ft trailer and I recently went from a GMC Yukon to a Ford F150/Raptor. The shank and old hitch works fine after some adjustments, but I noticed today I can't open the tailgate without it h...
Obviously it puts a greater bending moment on the back of the truck (like more weight) which will be more not able with the very compliant suspension of the Raptor. Not a lot though, guessing the equivalent of 100lbs more at the most. If you’re running a wdh and notice a difference you can crank up the wdh a bit more. Either way it is not going to be a major difference.
