swimmer_spe wrote:
So, here are my thoughts as to why it annoys me.
1) Why is it that when I press the Tow/Haul button the computer does not automatically lock out the top gear? If what everyone is saying is true, than that button should lock it out to prevent damage to the transmission.
2) Eventually I plan to buy either a 250 or a 2500. These would have manual transmissions (I hope), So, in a manual, do you not go into the top gear as well?
3) My truck is rated for 10,000 lbs. Why at 1/3 the capacity do I loose a gear? Would I loose 5th and maybe 4th if I was hauling my max weight?
4) Why was it that 3 years ago I towed a trailer almost double the weight at even faster speeds and it would stay in the top gear? In the summer of 2014, I drove across Canada from Victoria to Sudbury with a 1975 Terry TT 21'. It weighs about 5000 lbs. I was traveling at 110km/hr in Alberta/Saskatchewan/Manitoba. Driving from Toronto to Sudbury with a trailer weighing 3000lbs, It was hunting at 100km/hr. This is why I am concerned. Not because I cannot use the top gear, but because I never had that issue with my heavier one.
5) Who do I slap for a poor designed transmission/computer system.
1. You should read up on what the tow/haul feature does. (Owners manual maybe?) It will keep the truck from going into 6th if need be. But some driver input is required as the truck doesn't always account for many different factors.
2. The only truck left with a manual is Ram. New anyways. You may find an older truck with one. But even then, like number 1, driver input is required and in order to keep the truck happy and in the sweet spot you may not go into the taller gears.
3. What your truck is rated for isn't always practical. Under perfect circumstances and with the perfect load it may pull 10k. But your not gonna like it. You will run out of payload well before you hit the towing mark!
4. Your trans now is far and away better than they were back then I assure you. Those trucks back then did not have OD or the mpg your getting today either. Think of it like this...you had three maybe 4 gears then. Lock your truck in fourth (with no OD gears) and pull with it and see how well it does. Bet it handles it much better and I'd be willing to bet your mpg won't be any worse than back then either. Probably better. Remember, when not towing, the name of the game is efficiency.
5. Slap who ever you wish. But your wasting your time as the trans and engineering is much better. It's incumbent on you to learn your truck and how best to use it under varying conditions. Not the engineers. This is why they come with manuals and the ability to do a multitude of tasks asked of them.
