tuna_fisher's avatar
tuna_fisher
shifting camper
Went to town yesterday to get truck smoged with the camper on, some where it shifted a little and when I got home 1 turnbuckle was real loose and 1 real tight. Isn't there some way you can move you camper just a little using the jacks? How?
  • IIRC as you let the jacks down the tub of the camper tends to move away from you . I could have that backward but you'll know when you're doing it . So lift the camper so it's slightly off the bed then lower the side that needs to move away from you until it hits the bed , this should hold it in place while you lower the other side . It takes some playing around . The other thing to determine is why it shifter . Good luck
  • ppine's avatar
    ppine
    Explorer III
    The only way I know of is to raise the camper and move your truck under it. The tie downs that bolt to the frame are best and most secure.
