Lynnmor
Oct 11, 2016Explorer II
mike-s wrote:
What works great is to lower the tongue with the jack, set the rear stabilizers, then raise the tongue to take a lot of weight off the axle. Finally, set the front stabilizers then let the weight off the jack. Much easier than trying to lift weight off the axle using just the stabilizers.
Now you have the trailer sitting on its four corners bending the he!! out of the frame. Bad advice.
