Golfcart
Oct 12, 2016Explorer
The best way to eliminate the bounce is get those front corners stabilized as well.
When i first started campign in my single axle trailer I "discovered" pretty quickly that the hitch jack simple wasnt cutting it so i went to a local junk yard and got a couple scissor jacks for practically nothing and use them in the front corners
Do NOT pull all the weight off of your hitch jack. if the campsite is slightly unlevel the trailer frame will want to twist and you'll end up having cabinet/wall separation inside. Stabilizers(or front scissor jacks in my case) are meant to keep it stable, not lift.
