- beergardensExplorerNot sure how many miles are on your present fuel pump, but I would almost certainly replace it before the trip. With the transmission, however, I share the same doubts as you and would probably leave it alone. I knew someone years ago who had a transmission rebuilt proactively before a trip, and ended up being towed home with a transmission failure anyway.
- boosTTExplorerI wouldn't risk making the trans worse by opening up the case. I wouldn't touch it.
- MARK_VANDERBENTExplorerDoes anyone use lucas additive like I do ?? Another kind ??
- camping_manExplorerJust don't hold it in reverse too long backing in, that's sure to test the clutch seals in your transmission. Line pressure about doubles on a 4l80 in reverse. They have valve body fix kits to relieve that on those trannys. I found that out the hard way,800miles from home. Backed in my site, and it never drove out, all the seals were in now in the bottom of the pan.
- hawkeye-08Explorer IIIWhen you have serviced your transmission, did you notice anything unusual in the pan (you have serviced on regular basis, yes?)? If you have never had any symptoms (like slipping or irregular shifting), and you have serviced regular without any indication of problems and have not overheated trans, then keep your money for emergencies and enjoy your trip.
I was considering doing basically what you are when my daughter was switching coasts every 3 months (she worked on east coast and went to college on west, switching every 3 months). I did not want her truck to have transmission problems so considered changing it proactively, but ended up just servicing it. It has run fine for another 50k miles so far with no problems. - BurbManExplorer III
DownTheAvenue wrote:
What about the alternator, water pump, idler pulley, air conditioner, and power steering pump? I bet they all have 200,000 miles on them as well. Are you not considering replacing them, too? That is a lot of miles on those bearings and other parts. They could fail just like that transmission, even though they show no signs of failure right now. Get my point?
True, but these items are fairly common on a 1500 burb, and a roadside failure would mean a tow and a quick fix. A transmission job, even installing a Jasper, may mean several days of downtime depending on availability and shop time. I think some depends on the OPs planned schedule...if the trip involves several national parks with hard to get reservations a blip of several days could ruin the trip. - kvangilExplorer
Exactly...On a 2K-3K miles trip out west, any component can fail, or none at all. You may spend $2K-3K on rebuilding the transmission, then be stranded on the side of the road because the alternator, fuel pump, wheel bearings/axles, or something else gave out. I'd stick with doing the Preventive Maintenance, and hold on to the $2k-3K that you would've spent on the transmission for a "just-in-case" breakdown on the road. And make sure you have good road-side assistance. - DownTheAvenueExplorer
MARK VANDERBENT wrote:
and we now have 200,000 miles on a trans that has not been rebuilt.
What about the alternator, water pump, idler pulley, air conditioner, and power steering pump? I bet they all have 200,000 miles on them as well. Are you not considering replacing them, too? That is a lot of miles on those bearings and other parts. They could fail just like that transmission, even though they show no signs of failure right now. Get my point? - TachdriverExplorerMark:
Including installation of a Jasper transmission by a qualified mechanic cost me about $2500 to $3000. Be sure to google one near you for a better quote on you installation.
however I do believe in not touching it until you really need to. As you can see by these posts that a random repair/overhaul does not mean it was done right. Run it until you get some slipping or lose a gear.
Not to pull on Jasper but they install improved parts that have been known to be weak in the first place.
Until then:
Have your transmission serviced by draining and refiling the fluid at MFG recommended intervals. Do not recommend a flush.
install a transmission cooler if you do not have one.
Rob - MARK_VANDERBENTExplorerThanks for response. I think I will gamble and not touch it. I will however have extra money ready in case of emergency. Will let you all know how this works out in long run.
44,055 PostsLatest Activity: Dec 23, 2025
