Kayteg1
Aug 29, 2015Explorer II
Shower valves upgrade PICTORIAL
My so called "luxury" camper come with decent kitchen faucet, but cheap bathroom and outside shower valves.
Hated those things and they come some freeze damages so was on the market for good replacement.
Lately found thermostatically controlled kitchen faucet with diverter and shower, so that was exactly what I was looking for.
Model number DE-002
Had small issue with ebay seller who send it with no shower hose and stop answering my email, so will not recommend him.
Here is the old faucet that was pretty annoying to use and was wasting lot of water for adjustments.
Here is new faucet on the bench. It come with backflow preventive valves, but I did not install them as they would prevent winterizing.
Enlarging holes
Hooking up under the sink. I cut the pex and install threaded adapters where the faucet hoses attached to. Did not want to spend $60 on crimping tool, so used hose clamps on pex
Final look. The 2nd hole come very handy for soap dispenser. The dispenser bottle would not fit on it becouse of P-trap, but the dispenser come with long tubing that will suck the soap from bottle standing under the sink.
Now I set the temperature on right knob and forget it.
Open flow with left knob and will wait for warm water to come. No more going back and forth for flow and temperature adjustment. That can save quite some water.
Now outside shower. Bought that valve on ebay.
Cutting bigger hole for new valve
Attaching hoses to new valve. I was able to flex the pex enough to attach original fittings to new valve
Final look. That valve has plug in hose and temperature adjustment by turning single handle. It come with sink sprayer, but the hose will accommodate any standard shower.
I can store the hose in the compartment, but for sanitary reason will probably take it inside. Still have to figure out how to plug the other hole.
Model number DE-002
Enlarging holes
