Kayteg1's avatar
Kayteg1
Explorer II
Aug 28, 2015
Shower valves upgrade PICTORIAL
My so called "luxury" camper come with decent kitchen faucet, but cheap bathroom and outside shower valves.
Hated those things and they come some freeze damages so was on the market for good replacement.
Lately found thermostatically controlled kitchen faucet with diverter and shower, so that was exactly what I was looking for.
Model number DE-002
Had small issue with ebay seller who send it with no shower hose and stop answering my email, so will not recommend him.
Here is the old faucet that was pretty annoying to use and was wasting lot of water for adjustments.
Here is new faucet on the bench. It come with backflow preventive valves, but I did not install them as they would prevent winterizing.
Enlarging holes
Hooking up under the sink. I cut the pex and install threaded adapters where the faucet hoses attached to. Did not want to spend $60 on crimping tool, so used hose clamps on pex
Final look. The 2nd hole come very handy for soap dispenser. The dispenser bottle would not fit on it becouse of P-trap, but the dispenser come with long tubing that will suck the soap from bottle standing under the sink.
Now I set the temperature on right knob and forget it.
Open flow with left knob and will wait for warm water to come. No more going back and forth for flow and temperature adjustment. That can save quite some water.
Now outside shower. Bought that valve on ebay.
Cutting bigger hole for new valve
Attaching hoses to new valve. I was able to flex the pex enough to attach original fittings to new valve
Final look. That valve has plug in hose and temperature adjustment by turning single handle. It come with sink sprayer, but the hose will accommodate any standard shower.
I can store the hose in the compartment, but for sanitary reason will probably take it inside. Still have to figure out how to plug the other hole.
  • Unfortunately I don't have model for external shower and there is nothing written on it.
    I bought it on ebay from seller who does not offer any items at this time, so have no idea where it come from.
    Now thinking about it, all those holes in outside shower allow for the air to enter the camper as the door has no gasket.
    Under the sink cabinet has sealed door, but I don't like the idea about cold air circulating under my sink and shower, so will seal the upper holes that were used for original hose. You can see under the sink how I sealed gap to electrical cord compartment for the same reason.
    The sink holes covers are design for bigger holes and might not hold too well vertically, but I might give it a try. If not, caulk will work.
    For hose clamps on pex, I do have 150psi city water pressure, what always work well for testing RV plumbing.
  • You may be able to find a snap in plastic cap at a hardware store for the extra hole.
  • I hope the hose clamps hold on the pex pipe. I think you're rolling the dice on that. FWIW, I bought a pex crimp tool, the one with the two halves drawn together by bolts for around $20 at Menards.
  • Give us the model of the outside shower mod unit. Can't find it but looks great with the removable hose.
