theoldwizard1's avatar
theoldwizard1
Explorer II
Aug 17, 2013
Sleeping on a J-Steel Sofa
We are shopping for a new camper and like the layout of the Jayco Feather X23B. This model uses a 3 cushion J-Steel Sofa (found in many other Jayco campers) in the bump out as one of the beds. It appears from the pictures I can find, that you sleep across the 3 cushions. One person is up against the wall and "trapped" by the other person.
Has any one figured out a way to sleep the other way, using some custom cut foam to fill in the crack ? How short would you have to be to not have your feet hanging off the end this way ?
