eimac99's avatar
eimac99
Slide Binding Up
Our 2014 Arctic Fox 1140 has developed a problem with the slide. When it is on the truck it works fine, but when it is on the ground, the slide starts going out at an angle, makes a grinding noise and presses against the valance over the back window.
We called the dealership and were told that this is a problem they have seen in TC's with the big slides - the weight of the slide distorts and twists the camper. We were told to use the jacks to shift the weight of the camper slightly to one side and the problem should stop. Then once the slide is out, to relevel the camper.
It worked, but we are not happy about this. Is this really a common problem or do we have something seriously wrong and the dealer just wants to get us to go away. We are in Florida so there are no Arctic Fox dealers anywhere near us-- drove to Oregon to pick it up.
  • I'm glad it's not just us, but we have had the camper for over a year and this just started happening this week. Took it from Florida to Vancouver Island and back, why now?
  • Flexing is common. The camper needs to be supported properly and level to prevent flexing.
  • I used to have a similar problem with mine. It only happened when the camper was not leveled property before the slide was deployed. Mine did same thing, usually when a back jack was incorrectly positioned. It also only occurred on my large slide (I have 2). Don't think you should get to upset, the frame simply got flexed a little to much.
    Just work on your technique and it probably won't happen anymore.
