mobilefleet's avatar
mobilefleet
slide motor problems
got a 2006 Sunnybrook sunset creek trailer. Slide would not move either direction. I removed the sldie motor and took off the cover and found a stripped plastic gear with some shavings inside. Anyone know of a source to buy just the gears without having to buy a whole new motor? the motor has a serial number sticker on it and says 18 to 1 ratio, max 30 amp on it. Gear motor housing is stamped VMC who I assume is manufacturer.
  • It sounds as though you have a Venture Manufacturing landing gear and motor. They are wonderful to deal with and will ship directly to you.
  • mobilefleet wrote:
    nevermind I found a set, much cheaper than a whole motor
    Then please post the source of your find so others can benefit.
    Happy trails,
  • I appreciate it but that link is only for the whole motor, not internal motor gears
  • http://www.factoryrvsurplus.com/categories.php?category_id=169
