MFL
Feb 12, 2016Nomad II
PackerBacker wrote:Terry26 wrote:
Hi, I did forget to mention that I had Electrical AC connected as in doing so tried to eliminate a battery issue. So with only battery or AC electrical power is struggles the same.
Thanks
Does not matter, most slide systems require a good battery even if plugged into AC. The slides work on DC and typical converter/charger units do not generate sufficient power to overcome a weak or poor condition battery.
I agree,PackerBacker. Someone mentioned earlier, to plug cord into truck, with engine running. This will help, but not as much as good jumper cables, truck battery direct to RV battery, truck running.
Jerry
