Chuck_thehammer
Feb 13, 2016Explorer
A Weak battery could do this.. even with truck plugged in.. or Power Pole...
truck and Power pole goes TO the battery, then to everything else..
also check the connectors and connections at the controller of slide motor.. and to motor itself.. and then the SWITCH itself.
have BATTERY LOAD tested at auto parts store.. ONLY the 100 amp test.. and only the 100 amp test.. others are not worth your time, and has NO VALUE.
