troy t wrote:
Did a little You-tubing and I do have the Schwintek system. Grabbed a ladder and went up to lok at the top where the motor is and realized I need to replace the seal across the top. Doesn't look like a horrible job, has anybody done that?
Read about calibrating the Schwintek slides. Doing this will help your slides go in and out squarely.
Once you replace the one damaged seal lube the others with a silicone spray. I do the seal and the side of the slides to make them slick (so that the seal will slide easily). KEN
