wrgrs50s wrote:
SoundGuy wrote:
scott_dv wrote:
Any ideas? Is there an adjustment that can be made?
Yeah, start with make / model /year of trailer, make of slide mechanism if you can - pics would help as well.
Its a Bal Accuslide system if it's cable driven. The only adjustment is on the cables, which wont change how it sets in the opening. They only need adjusting if they have slack in them. There are 3 rollers that can be seen from the outside underneath the slide when extended. You might check to see that none of those are broken.
As suggested by 'wrgrs50s'
"There are 3 rollers that can be seen from the outside underneath the slide when extended. You might check to see that none of those are broken."
