campermamaExplorer IIJul 27, 2022Slide out questionHow can you tell if the slide skipped a few teeth or it's just out of adjustment? This is an electric thru the frame lippert slide out. Thanks!!
MFLNomad IIJul 27, 2022Can you visually see if there is damage to the teeth? If it is skipping teeth, it will be out of adjustment.Does it fit properly when fully closed? Does it seem square when fully open?If electric rack & pinion operated, they are normally dependable, and not hard for an experienced person to adjust.Jerry
Related ContentAdding power outlets in slide with no wiringSlide out roof questionarctic fox slide adjustmentSlide Out QuestionNewbie power question
