campermama
Jul 27, 2022Explorer II
Slide out question
How can you tell if the slide skipped a few teeth or it's just out of adjustment? This is an electric thru the frame lippert slide out. Thanks!!
MFL wrote:
Can you visually see if there is damage to the teeth? If it is skipping teeth, it will be out of adjustment.
Does it fit properly when fully closed? Does it seem square when fully open?
If electric rack & pinion operated, they are normally dependable, and not hard for an experienced person to adjust.
Jerry
