campermamaExplorer IIJul 27, 2022Slide out questionHow can you tell if the slide skipped a few teeth or it's just out of adjustment? This is an electric thru the frame lippert slide out. Thanks!!
campermamaExplorer IIJul 27, 2022I only moved it once since I noticed the issue, and only retracted it maybe half way then extended it. I think they moved at the same time. There was no noise or binding, moved smoothly.
Related ContentAdding power outlets in slide with no wiringSlide out roof questionarctic fox slide adjustmentSlide Out QuestionNewbie power question
