campermamaExplorer IIJul 27, 2022Slide out questionHow can you tell if the slide skipped a few teeth or it's just out of adjustment? This is an electric thru the frame lippert slide out. Thanks!!
MFLNomad IIJul 29, 2022Does the slide sit square in the opening, similar clearance, when looking behind the rubber wipers? I needed to move my whole slide toward the front of trailer 1/2 inch, to better fit, be closer to same on both sides.
Related ContentAdding power outlets in slide with no wiringSlide out roof questionarctic fox slide adjustmentSlide Out QuestionNewbie power question
