SoundGuy wrote:
SoundGuy wrote:
Your interpretation ... anyone who gives this idea any thought at all should easily recognize that any trailer which hasn't been completely lifted off it's suspension system is inherently going to rock as people walk around inside. Obviously if you attempt to prevent this by placing supports under any slide assembly that's going to put stress on the slide assembly, stress for which it was not designed to sustain. That's common sense. :R
NRALIFR wrote:
I doubt I’m alone in that interpretation. Just to be clear, it’s not WHAT you’re saying that’s at issue. It’s HOW it’s being said. If you’re response is making the OP feel dumb, then your delivery needs work. If you just can’t do it, then maybe you’re taking this little pass-time too seriously. Thanks for reinforcing my point.
2012Coleman wrote:
X10
Nah, this is just the same old tired response from the same few others on the forum who repeatedly jump at any chance to go after me, feeble and pointless as the attempt may be. :R BTW, it's not "pass-time", it's "pastime". :W
And FWIW, I had no intent nor interest in "making the OP feel dumb" and would apologize if he took it that way, I was just pointing out how obvious it should be to just about anyone who takes a moment to think about it what a poor idea it is to subject any slide system to forces for which it was not designed ... clearly others agree. ;)
These guys are right, SoundGuy. You make good contributions, but you do need to work on the delivery. On the internet, nobody can see your facial expressions or hear the inflection of your voice, making it easy to accidentally come across as a smarta$$.
