rickhise's avatar
rickhise
Slide out support
Fall I'm just starting to get our 28ft Sportsaman unit out.
Noticed most of the units parked around us had support braces
On there slide outs
Can u give me a few FYI 's on why some do an some
Don't. Common sense tells me the more the support
the better.
Do any u add em
  • Mandalay Parr wrote:
    Old-Biscuit wrote:
    Aftermarket sells LOTS of stuff......some good, some OK and SOME JUST TO GET YOUR MONIES
    Folks buy/use them due to 'marketing' hype....period.
    Slideouts are 'self-supporting' when extended.
    IF slideout 'supports' were needed don't you think RV MFG would supply them, require them, recommend them during the 'warranty' period to prevent issues that they would have to fix/repair ???
    NO...slideouts do NOT need or require supports.
    Using them CAN cause damage to slideouts due to the UPWARD pressure that slideouts are not designed for.
    X2
    Use them at YOUR own risk.
    The following is a statement directly from an RV MFGs owners manual
    Additional support jacks are not needed under the slideout.
    Damage can occur to your slideout room from improper use of aftermarket support jacks.
    X2
    X3
    On there slide outs
    the better.
    Maybe your common sense but certainly not mine :R ... probably the best way to torque your slide mechanism out of alignment. Slide supports are a solution to a problem that doesn't exist. :(
  • companies make things because people will buy just about anything.Such as "rv toilet paper"
    X2
    X2
  • maybe in the VERY early days of slideouts, supports were needed. Ancient history.
    When you put them out after leveling the unit, things happen. The earth moves under the jacks, the suspenion does a sag..anything to change the distance between the ground and the slideout.
    Only an inch or two "compression" can damage the slideout. My OPINION...FWIW, forget supports. Verify with your owners' manual or even the mfr or dealer.
  • Aftermarket sells LOTS of stuff......some good, some OK and SOME JUST TO GET YOUR MONIES
