Boband4
Mar 24, 2014Explorer
Good News. I emailed Lippert customer service (parts@lci1.com) on Sunday night, sending an explanation of what I was doing, asked for a color for color explanation on converting from the "old" single column design (2005 and older) to the "new" double column design (2006 and newer). Monday morning I received a diagram back with the color coding and the wiring labels. The conversion works out to be: Single Column (SC) Green is Motor CCW, White is Ground, Black is Power, White is Ground, and Red is Motor CW. The Double Column (DC) Black is Ground, Yellow is Motor CW, Green is Motor CCW, Black is Ground, and Red is Power. So...the conversion works out to be: SC Green to DC Green, SC White to DC Black, SC Black to DC Red, SC White to DC Black, and SC Red to DC Yellow. I made all of the connections temporarily, plugged in the switch, and it worked. Only problem was that when I pushed the switch to "In" the slide went out, and when I pushed the switch to "Out" the slide went in. I took the switch out of the mounting plate, turned the plate top to bottom and snapped the switch back in. All worked perfectly, and is now labeled correctly. I used durable butt splice connectors to make the final connections, mounted the switch in the wall and all is good. Thanks to all for following along and trying to help.
44,066 PostsLatest Activity: Jul 25, 2018
