- TachdriverExplorerBut wouldn't a reversed polarity 12v yield dark lights? :B
- Old-BiscuitExplorer III
RoyB wrote:
OLD BISCUIT - Sorry I reported the same thing to check. You was quicker in responding than I was haha...
Roy Ken
Don't know about quicker.....I'm a two finger occasional thumb typer.:B
OP has had to changed something recently OR switch has shorted internally but that usually ends up with no workie. - RoyBExplorer IIOLD BISCUIT - Sorry I reported the same thing to check. You was quicker in responding than I was haha...
Roy Ken - RoyBExplorer III will add have you replaced your battery terminals recently - maybe they are put back on reversed...
Make sure the PRINTED WORD NEG on the battery case goes to frame ground...
If they have been reversed then you should also look for an in-line fuse near the battery blown and two fuses in the 12VDC distribution Panel labeled REVERSE POLARITY. These three fuses also blow when the battery cables are reversed...
Your slide motor is usually connected direct to the battery terminals so they may placed on the wrong terminals as well...
Just something to check before moving cables on the back of the slide switch. I'm assuming the slide switch has worked correctly in the past???? Those slide switch connections just don't get reversed by themself.
Whenever we see questions like this the first thing folks ask is what have done to the RV trailer recently...
Roy Ken - Old-BiscuitExplorer IIIIS this something you have just noticed....something that has changed from before?
Have you done any thing recently to DC system....change batteries?
Battery cables correct?
If you have taken battery cables off and gotten them reversed....slide out would work backwards due to reversed polarity.
And the 'reverse polarity' fuses on converter may have blown....slide out directly wired to battery but if fuses blown nothing DC inside rig will work from battery without shore power/converter. - TachdriverExplorerPull Switch out and reverse wires….done!
44,056 PostsLatest Activity: Jan 01, 2026
