bfast54
Jul 19, 2013Explorer
yes....................you can do it manualy..................is it hyd, or motor?????
If hyd...................find the punp................you may find a valve, which you may or may not need to shut.....then there should be a place for a Jack handle, screwdriver works....you pump the handle...like a hyd bottle jack, and adjust the valve....for in , or out.
If Elec...should be a handle , small chrome in storage compartment..find a hole in side, or in a compartment, or just under ...fit the crank handle in , and turn ...clockwise, or counterclockwise.
You may have blown a ciircut breaker....if hyd... trace wire harness from pump to batt...should be a small plastic breaker/switch in harness...with a small button on it..press to reset,,,try slides
One of these should work for you.
Please let us know, if this works.
44,071 PostsLatest Activity: Aug 30, 2026
