hershey
Jul 19, 2013Explorer
Locate the motor/gear assembly under the slide. On that assembly, there is "usually" a bolt that can be easily tightened or loosened which actually bypasses the motor and will operate directly the gear drive of the slide out. I don't suggest an electric drill for this or impact wrench, just a simple socket and ratchet drive.
Admittedly, I'm not at all familiar with your particular unit, but the above is a pretty generic answer for moving the slide when power is lost.
44,071 PostsLatest Activity: Aug 30, 2026
