Clarkston
Jul 19, 2013Explorer
The bullet if i am correct used the bal accuslide system it is electric with chain and cable, you need to see if it is on the upper part of the slide above the valance or below the slide ie under a couch on the end of 1 side of the motor is a hex head drive this has to be turned with a flexible extenstion you should have received from the dealer in your paperwork package turn this end using the flex exstention with a electric drill.
44,071 PostsLatest Activity: Aug 30, 2026
