Howdy, Our new Jayco has a problem with the bed room slide it will not move either way. The motor seems to spin but will not connect to slide. Anyone have this problem? TIA
Once you get the side in, get the dealer to check out the whole thing.
I had this happen once to a trailer where the slide was misaligned and the other time to my motor home where the floor of the slide out had warped due to water damage. In both cases, the shear pin failed repeatedly.
