Howdy, Our new Jayco has a problem with the bed room slide it will not move either way. The motor seems to spin but will not connect to slide. Anyone have this problem? TIA
WE were told by Jayko that the motor rarely fails but the washer you showed does all they do is redo the conic portion and all is well again. We were not so lucky as the NUT that the shaft screws into free wheeled and had to be reset.
Just be careful and don't run in or out till the "clutch" slips.
