ScottG
Jul 21, 2014Nomad
Since you hear the motor running it's obvious the switch is fine so the next thing I would look at is the so-called "Shear pins". They are simply 1/4" x 2" grade 8 bolts that go through a square tube that located under your slide and runs the length of it. There will be one at each end.
44,059 PostsLatest Activity: Mar 18, 2026
