ab257's avatar
ab257
Slideout problem
Having a problem with our dinette slideout. It is a simple Power Gear twin rack and pinion driven by a single motor. The slide room goes out until the flange on the inside of the slide room hits the inside wall of the camper and the motor kicks out on high amps (apparently that is the way Powergear designed these, with a high amp stop switch).
The problem is when it comes in, it stops when the flange that is a part of the outside wall of the slide room hits the outside wall of the camper, or at least it is supposed to.
The outside wall flange has weakened over time and now it flexes when it comes in and hits the wall so the slide room comes in further than it should. Not much, but enough so the end of the rack comes off the pinion gear on the rear rack and pinon and the pinion gear starts slapping against the last tooth until the front rack comes in and kicks out the motor.
Then when you push it out again, since the back rack is not on the gear, it misses for a second or two until the front rack pushes the slide room out enough so the back rack catches, and now the slide room is cocked with the front out an inch more than the back.
It wasn't until I got back there with a boroscope that I realized the spur gear was coming beyond the end of the rack. It doesn't help that the way they cut the end of the rack the last tooth is just a little stub.
I'm talking with the manufacturer and a local RV dealer, but I'd like to know if anyone else has run into this problem, and what the resolution was.
  • It is a 2007. Thanks for all your comments. I'll update with how things turn out.
  • Thinking about this some more seems the root of the problem is the slider wall flange. You don't list the year model of your TC. Is it possible there is a problem with the seal? Why is the flange flexing? This needs to be replaced or repaired.
  • I haven't had any issues with either of my slides. If you are already talking to Host, I don't know what other data point I could provide other than I believe it is described in the manual.
  • You should have said you had a problem with your Lance slideout then you would get lots of responses saying that's why I didn,t buy a Lance.
  • It sounds to me like they may have cut the rack a little short, or installed it slightly too far to the inside.
    Probably the solution to fix it "right" is to pull the slide completely out of the camper, and install the correct-length rack, or install the current rack correctly.
    The short-cut solution would be to devise some sort of stop to prevent the slide from coming in too far and coming off the rack.
  • That would do it, but there are no screw stops for retracting.
  • Not sure what brand of slide system I have but it has adjustable screw stops that are set to coincide with full closure of the slide.
