plasticmaster's avatar
May 26, 2016
slides first or stabilizer jacks first?
On a travel trailer with 2 large slides on one side, is it better to run the slides out first, or deploy the stabilizer jacks first? Thanks.
  • I've always been in charge of the outside set up while my girlfriend gets the inside of the RV ready putting stuff we packed in to better places for use while camping. The first thing we do is put the slides out so she can do her thing while I'm leveling and putting the stabilizer jacks down. I really don't see how it matters either way, but that's just how we've done it for years. Allowing her to get inside right away cuts down on her impatience level while I get everything set outside as well. :) And you KNOW that's a plus!
  • We level first (with slide side slightly higher), then deploy slide, then put stabilizers down. If I put stabilizers down before slide goes out, then the slide side seem too tight and the other loose. That is just how I do it, I don't overthink it.... I have no problems either way really. I also check chocks and stabilizers after an hour or two. Tires cooling and soft ground can loosen things up...
  • I used to stabilize first then deploy slides but was finding the stabilizers on the non-slides side were loose and the slide side had too much weight on them. Now I deploy slides first and then stabilize. I just compensate slightly on leveling knowing that the 2 slides will change the levelness when deployed.
  • ford truck guy wrote:
    Level and stabilize first... Then deploy the slides
    This seems to be what most manufacturers say, but I think it is important that the stabilizers not be over tightened. I think this is easier to do than some folks realize, as I have done it and discovered it when an interior door started binding against the door jam.
    I may be wrong, but on my 2002 Sunline trailer, the instructions were to extend the slide (after trailer is level) and then stabilize. I did it that way for 10 years without any slideout problems other than a faulty ground wire on one occasion.
    When we got our Minnie, the instructions were stabilize, then extend slide. But, with the reputation of the Lippert slide mechanism in mind, I have continued to do the opposite. I level the trailer, extend the slide out and then stabilize. It eliminates the risk of and torquing of the frame. And, so far (knock on wood!) we have had two camping seasons without and Lippert slide out problems.
    BUT....THIS IS JUST WHAT I DO...
    It is propbably safer to follower the manufacturer's direction, at least while the unit is under warranty. Just don't over tighten the stabilizers!!
