bobndot
May 26, 2015Explorer III
With a soapy solution spray the lines from the air fill valve to each bag to see if its the line, connection or bag itself.
Some installers are lazy and use one fill valve then "T" it off to each individual bag. The better method is to use two fill valves with direct lines to each bag for side to side leveling.
I would think its the connectors if they both are leaking but...you never know.
The fittings at any "T" or at each bag have a tendency to leak especially if the bags are pre 2008. The AB industry upgraded those simple valve seats where the line gets connected to the valve at each bag. The upgraded seats can be bought and added on . Try to tighten things up snug.
Check the AB mfg. for possible upgrades if you see bubbles where the leak is at a valve if tightening them doesn't work.
44,052 PostsLatest Activity: May 05, 2016
