campigloo
Sep 09, 2018Explorer
Small A/C
I may be looking for something that doesn’t exist. I want a small, 5000 btu or less, roof mount ac. All I want to do is cool the bedroom. I want one that a 2000w generator will power. Any ideas? Th...
SoundGuy wrote:time2roll wrote:
I assume a 9200 would run off a 2000 generator in most conditions.campigloo wrote:
I don’t know. 9200 btu would be ~ 2650W
If successfully starting a roof mount A/C with a genset is the issue then the better solution would be a 13,500 BTU A/C equipped with a Micro-Air Easy Start Soft Starter Kit powered with the new Honda EU2200i which is significantly more powerful than it's 2K predecessor or indeed any 2K inverter genset currently available. If the OP felt a 9200 BTU A/C would be sufficient the EU2200i would just laugh at the task. :p
